How do I customize Sense clock face and stats?
My fitbit sense displays the red circle. Hoe to fix this problem?
4 REPLIES 4
Hi @QuestionSense,
Can you attach a picture so we can see what's going on?
one cruise ship at a time!
Pixel Watches 1-4 I Charges 3-6 I Versas 1, 2, and Lite I Inspires 1 & 2 I Ionic I Alta HR I Flex 1 I Aria 2 & Air I Senses 1 & 2
Thank you for your support.
Please check the link:
https://www.reddit.com/r/fitbit/comments/kr3asg/fitbit_sense_how_to_change_default_today_screen/
I have the same problem.
So are you trying to see all your stats on your main screen or trying to remove something from the "Today" screen? There's a huge difference and in order to guide you, we need to understand what you want to do.
@QuestionSense Welcome to the Community. @DramaQueenDiva Thanks for stopping by to help our new friend.
@QuestionSense Thanks for the link provided which describes your question. Before anything else, let me share that the first picture is related to the Today app which will show all your stats. If you want to adjust the order of these stats, just follow the steps described in this hep article under Check Widgets. Take in mind that you can also customize the order the stats of certain widgets such as Core Stats, Advanced Stats, EDA Scan and Fitbit logging.
That being said, please note the Today app cannot be set as the default screen of your Sense. However, I'd encourage you to visit our Fitbit App Gallery which provides a variety of clock faces to fit your needs and style. Some of them will allow you to set a primary stat so you can check your data at glance. To change the clock face, I'd recommend the steps described in this help article.
Hope this helps.
