04-05-2023
18:17
07:48
LizzyFitbit
04-05-2023
18:17
07:48
LizzyFitbit
I installed new clock faces but I deleted a clock face by mistake and I don't know what it was called.
Is there a way to get it back.
Best Answer04-06-2023 20:42
04-06-2023 20:42
Hi @warriorgirl76 - as @Clove6060 rightly says, you will have to search for it again as there is no history of downloaded ones.
However if you found it via a Google search go back to browser history you may find a reference there, search the history for gallery.fitbit.com.
Btw you can't normally delete the active clock face unless you have loaded more than 5 clock faces during a search/try for one you like.
Best Answer04-06-2023 04:44
04-06-2023 04:44
If you know some of the features animation and whether analog or digital etc, you can put those
Search words in the search eyeglass. It will help you narrow down some of the watch faces and limit the faces populated.
04-06-2023 20:42
04-06-2023 20:42
Best Answer04-18-2023 12:27
04-18-2023 12:27
I have sorted it out thank you for all your help, I went on google images and scrolled through all pictures.
