05-20-2021
17:20
17:30
LizzyFitbit
05-20-2021
17:20
17:30
LizzyFitbit
Any way to remove Pandora and Deezer from my apps?
Best AnswerGo into the app on your phone, tap on your profile picture on the top left of the screen, tap on your device image, then tap on Apps.Then tap on the app and uninstall it.
I did the same as I have no use for them.
Thanks for your response, but it does not allow me to remove it. I can remove other apps but not these two..
Best Answer@Vtxk if it doesn't let you remove it i suggest you uninstall the app depending on your phone you might need to clear the Cache for fitbit then reinstall the app and see if you can now uninstall those apps.
