How do you change the name of the exercises such as Tennis to Racquetball like you could on Versa 2
I want to modify the name of exercises that are similar
2 REPLIES 2
Choose the workout exercise, this is the only manual one you can edit the type. You should also be able to edit the auto detected exercises @steveo57
Simply tap the pencil.
To this point you are only able to tinker with manually logged/started exercises (meaning you go to exercise and manually log one). If you go to Exercise app and start an activity like "Walk", then you can't edit this.
I think OP was wondering if there is a way to change the name "Walk" to something else in your list of exercises under the Exercise app, and I don't believe this is possible. You are also unable to edit the display order although once you do an activity it jumps to the top under a "recent" section. You can also create a shortcut to a specific exercise when you double press the button on the side, which brings up a list of shortcuts.
