05-25-2022 17:37
05-25-2022 17:37
My fitbit since is 4 hours of how do you reset the time
Best Answer05-25-2022 20:40
05-25-2022 20:40
Hi @Hildy60 - normally when you sync it should set the time correctly, however if you changed time zone it doesn't always pick up the change automatically.
To fix it, in the the Fitbit App
