12-26-2021 23:50 - edited 12-02-2022 23:35
It cannot be stressed strongly enough how important it is to clean the 4 contacts points on the back of your watch especially if experiencing a slow charging message or no charging. The holes are prone to collecting deposits very quickly,
If you are sure the terminals are clean on your watch and charge cable, and you have reviewed Why isn't my Fitbit device's battery charging?, the charge cable may be faulty.
To verify, check the 4 pins are equally prominent and properly located using the back of your nail carefully to check the spring pressure is the same on each pin, especially the left bottom one.
If when using a computer port to charge the device it is not recognized by a sound it would indicate a problem.
Do also try removing the USB plug and then reinserting for a few minutes, Then while still being connected press the side button for 3 or 4 seconds, you may feel a vibrate. Try this process several times.
If it's under warranty you can contact Fitbit Support directly. They should send you a replacement charge cable.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
You can also buy them online if out of warranty.
Warning: if your watch gets hot when charging stop immediately, it is dangerous as there is most likely internal damage, possibly from water getting in.
10-04-2022
09:39
06:28
10-04-2022
09:39
06:28
Hi everyone, and welcome to our new members.
Thank you for sharing your experience and troubleshooting. If your Sense is not charging, please follow the charging tips in this Fitbit help article Why isn't my Fitbit device's battery charging?
Hope this helps!
12-27-2021 00:03
12-27-2021 00:03
Thank you It’s brand-new it’s only come out in the box yesterday that’s why am asking
12-31-2021
05:22
10:56
AndreaFitbit
12-31-2021
05:22
10:56
AndreaFitbit
thank you I have read all of this, followed directions and even used my old charging cable, still nothing. I’ll contact support.
Moderator edit: format.
01-18-2022 12:33
01-18-2022 12:33
Same as mines 1 year old got for Xmas 2020 use it for everything sleep, exercise BP u name as have health issues I rely on this as my records for my issues and indicates areas to what have I ulter or was I tired less sleep etc I swear on it like part of my body so struggling not have it thinking if don't hear back like I was said through email I'll go to place were friend brought it and see there outcome as have no idea WARRENTY on NZ sense watches. Won't surely be 1 yr would have be two at least.
02-02-2022 08:20 - edited 02-02-2022 08:25
I got the same issue. My roommate has the charger and also has this same problem on the same pin. Plenty of Amazon reviews of genuine FitBit chargers that show the exact same problem on the same pin. The Chinese knockoffs on Amazon and others, which I DO NOT RECOMMEND, are even worse with many users reporting melting and fires. I assume that the charging current is carried by the internal spring and is heating up the spring past it's temper temperature. Spring tension vs. current carrying capacity?. My Sense is 10 months old, roommate's is 11 months old. Both getting charged via high quality, fully USB compliant, chargers.
The failing pin is the ground pin.
02-02-2022 10:23 - edited 02-11-2022 07:35
Customer support has been contacted at 9:01 AM and a replacement has been ordered. Update 2 Feb 2022 1:30 PM CST: Charger has shipped.
Thank you FitBit for the prompt service!
Update 7 Feb 2022: Per USPS tracking the charger is expected to arrive on Tuesday 8 Feb 2022.
Charger arrived on time.
02-05-2022 11:18
02-05-2022 11:18
The charging cable is an issue. I am now on my 4th cable in about 14 months. FitBit did replace it once, but won’t replace the one I purchased even though it has a one year warranty - cable was bought in the summer of 2021. The same pin on this cable always goes bad. They know it’s an issue and don’t want to fix it.
02-05-2022 11:47
02-05-2022 11:47
Hi I'm shocked reading yours and hearing that alot brought from Amazon which if buying expensive watch, Fitbit buy from only company that's my opinion. But fire that now makes me want make sure I keep an eye on it , normally when I'm HM and only charge for recommended time and always checking it. Maybe ones that it's gone on fire with have not used same charger to plug wall as given and maybe left Fitbit on all night as mines never got hot will say that. Good keep reading people's issues info mine charger wasn't issue like all but could be lots reasons behind pin too thanks as it's made me aware now on charger issue with fires keep eye out. So did u resolve your problem in the end.
02-12-2022 21:14
02-12-2022 21:14
I think it's my charger one of the prongs is shorter than the others. Thank you for your help.
02-13-2022 06:58
02-13-2022 06:58
@Pinkrocketmr2 Bought mine on Amazon. Works great. They offer a protection plan --- Asurion protection plan with 24/7 tech support. Drops, spills, and cracked screens are covered from the date of purchase. All other malfunction coverage begins after the manufacturer's warranty ends.
02-24-2022 10:37 - edited 03-05-2022 16:59
Same here I am on my 4th cable and wont be buying another. Time to buy another brand me thinks as it is always the top LHS prong that burns out or gets stuck.
03-05-2022 15:35
03-05-2022 15:35
Mine too.. out of the box yesterday..
03-14-2022 12:10
03-14-2022 12:10
I always my watch on the charger in the mornings when I get ready. Of course it's not syncing because watch is off. Issues started yesterday because my stats weren't showing up, so I did go into my settings and shut it down to see if my stats would show up and my watch will not turn back on.
03-23-2022 23:53
03-23-2022 23:53
Guy thanks for that advice, but the Fitbit is new, although the invoice say refurbished oddly, and the charging points are gleaming. There is no obvious button to press to turn the Fitbit on, i am just squeezing the sides of the watch??
03-24-2022 00:03 - edited 03-24-2022 00:05
@PoultneyM - if it doesn't come on when charged either the watch or charge cable or power source may be faulty.
For the button indentation position, See in the manual
05-12-2022 12:33
05-12-2022 12:33
I have had exact same issue with Fitbit Sense battery charger on multiple occasions. I have ordered two more charger cables. Have had two failures so far -third failing soon. Thank you for insight as to source of problem.
05-21-2022 17:07
05-21-2022 17:07
I have now had 3 chargers fail in the last year and a half. Always one of the pins recessing. No help from fitbit since I bought it from Costco. I don't want to return it just because of a faulty charger design!! Very frustrating.
05-22-2022 05:23 - edited 05-22-2022 05:31
Just buy one on line. You can get it delivered for less than $10 and end the frustration of dealing with Fitbit.
This one has been thrown out there but I can’t recommend cause I have no experience with it. There are a lot out there on Amazon.
I am still on my original charger from 11/3/20.
http://guytec.com/Fitbit/#Charge
05-23-2022 15:22
05-23-2022 15:22
VERY common problem.
The Bluetooth on my Sense died about 3 days after it arrived, the replacement has worked fine.
The week after it arrived though it stopped charging. Turned out to be the recessed pin syndrome.
Google research revealed it is a very common problem. It is always the same earth pin.
Opinion appears to be that the projecting charge pins short out on the metal body of the watch when you connect it and sometimes blow the spring, which seems to act as a fuse. 3 power pins, one earth pin, makes no sense (pun intended).
I went and bought another cable.
My solution has been to always connect the cable to the watch BEFORE plugging the USB into the charger.
I haven't had a repeat of the problem in the weeks since.
05-24-2022 23:42
05-24-2022 23:42
Thanks Guy! Much appreciated! However, my watch has been thoroughly cleaned and my wife is able to charge her Sense on both our chargers. My watch is not connecting to either one. So frustrating!
