12-26-2021 23:50 - edited 12-02-2022 23:35
It cannot be stressed strongly enough how important it is to clean the 4 contacts points on the back of your watch especially if experiencing a slow charging message or no charging. The holes are prone to collecting deposits very quickly,
If you are sure the terminals are clean on your watch and charge cable, and you have reviewed Why isn't my Fitbit device's battery charging?, the charge cable may be faulty.
To verify, check the 4 pins are equally prominent and properly located using the back of your nail carefully to check the spring pressure is the same on each pin, especially the left bottom one.
If when using a computer port to charge the device it is not recognized by a sound it would indicate a problem.
Do also try removing the USB plug and then reinserting for a few minutes, Then while still being connected press the side button for 3 or 4 seconds, you may feel a vibrate. Try this process several times.
If it's under warranty you can contact Fitbit Support directly. They should send you a replacement charge cable.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
You can also buy them online if out of warranty.
Warning: if your watch gets hot when charging stop immediately, it is dangerous as there is most likely internal damage, possibly from water getting in.
01-11-2023 19:34
01-11-2023 19:34
Have two senses and two charging cables. The top left hand poles on both charges are no longer protruding same as yours, so not charging. Fitbit are sending two new cables
01-15-2023 12:50 - edited 01-15-2023 12:59
Welcome on board, @BigAl55.
Thanks for joining this thread and letting us know about your Sense. While I'm glad you're receiving other charging cables, I'm sorry you've had this experience with your watch. Your feedback is appreciated and please know we'll keep working to improve our products.
Best Answer03-08-2023 16:42
03-08-2023 16:42
The recessed pin on the charger cable is a repeated issue by several users. I now have a 2nd cable with a sunken pin. Fitbit will replace the original that came with the watch. The 2nd was bought through a large chain store so they will not replace that one. I do not plan to purchase another Fitbit product in the future unless they use a different connection system (one with weaker magnets, or with a flat pad magnetic charger instead of ones with pins. The directions for charging a Sense should also include connecting the charger to the Sense prior to plugging into a USB. To be extremely careful when connecting pins to the watch, etc.
Customers keep buying charging cables (or get a replacement if the watch is under warranty). There should be a design recall on the chargers. No amount of cleaning will help is a pin is recessed. It is a very common defect and if I had known this before purchasing a Fitbit, I would have looked elsewhere.
03-12-2023 15:17
03-12-2023 15:17
Welcome to the forums, @Kaydee2020.
Thanks for taking the time to share your thoughts about the charging cable. I see where you're coming from and I apologize for this inconvenience. As mentioned before, every feedback shared by our members helps us to keep working on our products, and improve the experience with them.
I went ahead to check your details and it seems you already have a case created. I'm sure our Support team will continue helping you so please keep an open communication with them.
Best Answer03-28-2023 00:53
03-28-2023 00:53
One pin is noticably less prominent so is that the problem?
Best Answer03-28-2023 00:58
03-28-2023 04:25
03-28-2023 04:25
Yes. If you look through the posts in here there are photos of which pin can become recessed. I have had 2 chargers become defective (recessed pin) within the year and received replacements. Word of caution if buying a cable from another store. Check their return policy. Not all stores will grant a year for returns on electronics and accessories.
06-21-2023 08:45
06-21-2023 08:45
nope - none of this resolved my issue. have new charger now & still have issue.
08-01-2023 20:02
