01-14-2021
08:09
07:57
WilsonFitbit
01-14-2021
08:09
07:57
WilsonFitbit
Bought it and setup. Wore it for 3 days. Noticed it ha not synced after the second night. Can not get the Sense and phone to connect. Please help.
Best Answer01-14-2021 08:43
01-14-2021 08:43
Try these tips, best I can do without knowing what phone you are asking help for.
Best Answer01-15-2021 07:56
01-15-2021 07:56
Hello @KennyPhil Welcome to the Community Forums! @Rich_Laue Thanks for your input!
If by any chance you unpaired your Sense from your phone, I would suggest you to remove the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request. Also, please make sure no other mobile devices are nearby as this can interfere with the set up or sync process. For question about setup, please check: How do I set up my Fitbit device?
If the syncing difficulty persists, you can also refer to Why won't my Fitbit device sync?
Keep me posted.
