03-01-2021
00:53
11:58
WilsonFitbit
03-01-2021
00:53
11:58
WilsonFitbit
I get vibrations at midnight to tell me it is midnight! And last I got a vibration to say the active minutes are over. This is all disrupting my sleep. Does anyone no how to stop it
Best Answer03-01-2021 06:18
03-01-2021 06:18
Your reminders might be on for midnight. I just got a sense so im still learning
Best Answer03-01-2021 07:40
03-01-2021 07:40
You can also turn on Do Not Disturb on the watch.
Best Answer03-01-2021 07:43
03-01-2021 07:43
Hi, @Alicole19 & @Nishikigoi welcome to the community. You can disable notifications among other things by engaging "sleep" or "do not disturb" In your Sense swipe left to "settings" > swipe up to and touch "quiet mode", Focus mode, Do not disturb & sleep mode should be "off". Touch Schedule mode and switch "off-hours" on then swipe up and set a start & end time>swipe left to return to the clock face. This arrangement will engage "sleep mode" between the time you have set, alarms will still function. FYG Sleep mode mutes notifications, calls, and the display will not disturb your sleep. Do not disturb disables notifications. See page 23 of the manual here .
I hope this helps.
Cheers
Gr4ndp4 | UK
03-02-2021 08:28
03-02-2021 08:28
Check your daily goals. Users have been known to set a daily goal to zero.
Then when midnight comes, the user hits zero for the days goal and they get a celebration.
When the vibration goes off at midnight, the key is in knowing what is displayed on the tracker.
Best Answer03-02-2021 09:57
03-02-2021 09:57
You need check alarm on the watch itself, you should be able to disable it.
Best Answer03-02-2021 20:31
03-02-2021 20:31
If the other options don't fix it you could check your clock face does not generate the vibrations, by trying a different one, if you are using a non Fitbit one.
