04-08-2022 20:34
04-08-2022 20:34
My fitbit sense started vibrating in the dead of night and woke me up. I do not understand why. Is there a log that can be accessed to find out why?
04-08-2022
22:09
13:03
04-08-2022
22:09
13:03
Hi @the_bomb - it could be a low battery warning or an incorrectly set move hours and it is prompting you to move, and check your alarms to make sure they aren't mixed between am and pm.
One thing to do is to set a Sleep schedule in the watch settings, this way for sure you won't be receiving calls or notifications.
The only way to trace it is to see what it was telling you, and if your watch face can give alerts then disable them at night and remember to enable them in the morning.
