08-09-2023 17:53
08-09-2023 17:53
I want to reorder the list of exercises in my Fitbit Sense. Every post talks about steps that are not accurate for the Sense. I believe it may be since I recently migrated my Fitbit account to Google. Can someone help?
Best Answer08-10-2023 05:00 - edited 08-10-2023 05:05
Hello @JUDYINSC and welcome to the Community. I looked at your public profile and see that you are a long time Fitbit user. Your Sense is different from your previous Fitbits that had Exercise Shortcuts in the app. All of the shortcuts are on the Sense itself and posts about older models don't apply. You see that list when you tap on the Exercise app. As you use shortcuts, your list gets separated between Recent and All Exercises. You Recent list holds the last three shortcuts you used. Then there is the rest of the list and you can't edit it.
This "improvement" has mixed reviews among users. Some users, like me, definitely want more shortcuts stored on the device. My preferred shortcuts change with the seasons. But there are some that I will never use and can't remove them.
It doesn't make a difference that you have a Google account.
Laurie | Maryland
Laurie | Maryland
08-10-2023 05:05
08-10-2023 05:05
Thank you for the quick reply. I tried for over an hour to get it updated. I had to recently reset my Sense so everything went back to the standard list. I guess I will just have to exercise now to get it set to my faves. 😉
Thanks again!
