09-08-2021
03:47
04:26
09-08-2021
03:47
04:26
How much does the shipment and the new device cost when sending your broken devise to FITBIT and receiving a new one?
Best Answer09-08-2021 04:00
09-08-2021 04:00
Make very sure it is broken first because you are unlikely to get a new one as a replacement from Fitbit directly.
If you have the option take it back to where you bought for a new replacement.
Best Answer09-08-2021 04:24 - edited 08-28-2023 09:07
Hi there, @Liam2567. Welcome to the Community Forums.
I've seen that you still have an open case with our Support Team regarding the issue with your Sense and the return process. In order to receive an answer to your inquiry, I'd suggest you to ask this to our team so they can provide you with the correct information as every case is completely different from the others.
