08-05-2021 18:03
08-05-2021 18:03
Is it normal for the Sense GPS to be this inaccurate during runs? I'm not talking about distance, but rather the actual path that's recorded by the GPS:
I'm running up and down on the same side of the road on a fairly narrow sidewalk, yet the Sense GPS shows as if I was running up and down on opposite sides of the road. It's like this for me on every single run I track.
Best Answer08-05-2021 18:58
08-05-2021 18:58
Hello @dave98235! I have the same issue and I think this is normal for such a small GPS unit to track a tiny sidewalk. If for whatever reason its an error try contacting Fitbit support here.
If this answer works please mark this post as a Best Answer. ~ K.K Designs
Best Answer08-05-2021 19:33
08-05-2021 19:33
That's unfortunate. I guess it's also normal that it seems to struggle with any sort of curves (e.g. it often shows my path as cutting through several houses)?
I upgraded to the Sense from a cheap fitness tracker which also exhibited similar issues with it's built-in GPS. I was hoping the Sense would be better in this regard.
