Is it possible to remove unused exercises? I don't need all the exercises it comes with by default... Thanks
Best AnswerI don't think you can remove them, but after you use any one, it will go to the front of your list, intelligently self-ordering itself so the ones you don't use will go the end and can be ignored.
