12-25-2020
13:28
15:46
LizzyFitbit
12-25-2020
13:28
15:46
LizzyFitbit
Is the band on the Fitbit sense easier to change than the Versa ? Near impossible to change that strap.
Moderator Edit: Clarified subject and updated label
07-08-2021 13:44
07-08-2021 13:44
Found this... figured it out... once I saw how he does it...
https://community.fitbit.com/t5/Sense/To-change-bands/m-p/4473979#M682
12-25-2020 14:33
12-25-2020 14:33
Hi, @Steph3563 , the original Versa, the Versa Lite and the Versa 2 all attach their watchbands with traditional pin mechanism which can be quite fiddly.
The Sense and the Versa 3 both use an easy clip on band which I think most people find much easier for swapping between bands. The clip is plastic so it may be that they are a little less durable, however, but if used gently hopefully should be okay.
I hope this helps. Welcome to the forums, and happy holidays!
07-08-2021 13:31
07-08-2021 13:31
I'm finding it nearly impossible to remove the original band... 😞
07-08-2021 13:44
07-08-2021 13:44
07-09-2021 15:44
07-09-2021 15:44
Hi @JAKCA. I'm glad to see you around the forums.
Thanks for letting us know about this link which describes how to change the Sense bands. I'm glad you sorted this out and I'm sure your post will help other members experiencing similar issues. In case you have some spare time, I’d like to invite you to visit our Health & Wellness board where you can find inspiring stories, meet more people and start your own topics.
Have a good day.
