11-27-2020
23:08
16:08
LizzyFitbit
11-27-2020
23:08
16:08
LizzyFitbit
Is the heartrate issue many people have reported fixed with OS 5.1?
https://community.fitbit.com/t5/Sense/Sense-Heart-Rate-Sensor-Tested-on-YouTube/td-p/4515918
https://community.fitbit.com/t5/Sense/Fitbit-Sense-and-Heart-Rate/td-p/4507754
https://community.fitbit.com/t5/Sense/SENSE-Heart-Monitor-acting-weird/td-p/4581370
https://community.fitbit.com/t5/Sense/Sense-records-inaccurate-heart-rate-readings/td-p/4520718
https://community.fitbit.com/t5/Sense/SENSE-gives-a-false-heart-rate-value/td-p/4571869
Moderator Edit: Clarified subject and updated label
Best Answer11-29-2020 00:37
11-29-2020 00:37
I would say it has improved. When I compare it now to my OH1 arm strap (which was always pretty close to my previous Ionic) during exercise, it is definitely more aligned. I have the feeling it detects a rise in hr faster than before. However, Desfit (YT) promised to do a test within 2 weeks and the quantified data scientist (also YT) promised to do a new test once new firmware was out. Can’t wait to see the results.
11-29-2020 02:39 - edited 11-29-2020 02:48
I don't see any significant change in heart rate accuracy. It is still very accurate in measuring heart rate during sleep, rest, walking, running and cycling. But it is still a hot mess during weightlifting, hight intensity interval and circuit workouts. Average heart rate is up to 20 bpm off, while the difference can go up to 50 bpm during the individual data points.
Edit: conclusions above are made by comparing the data to Polar H9 chest strap.
Best Answer11-29-2020 03:33
11-29-2020 03:33
@Mateos wrote:I would say it has improved. When I compare it now to my OH1 arm strap (which was always pretty close to my previous Ionic) during exercise, it is definitely more aligned. I have the feeling it detects a rise in hr faster than before. However, Desfit (YT) promised to do a test within 2 weeks and the quantified data scientist (also YT) promised to do a new test once new firmware was out. Can’t wait to see the results.
Yeah, I feel it is a bit of a improvement. When resting it seems slightly more accurate. It still jumps a bit, (eg: when lifting rist to see it still starts of at a high number, eg: 72 then quickly reduces down to say 61, I think this maybe more a screen updating issue) but no where as much as before
I've tried wearing my Fitbit Charge 2, Sense and my Generation 1 apple watch
It seems on average that it usually works out at Charge 2 lowest, AW in the middle and Sense highest.
So I'm resting, C2 will say 56, AW 57 and Sense 58.
I could understand the C2 under reading.
