Just a week old Fitbit Sense battery drains in less than 48 hours
Just a week old Fitbit Sense battery drains in less than 48 hours. Sync is from Android App looks like a bit wuth make as i see common battery complaints accross sense.
8 REPLIES 8
Snore detect is understandingly a big battery user if you have that turned on.
Likewise for the SpO2 sensor app
@Ukprash Always on Display also eats a lot of battery!
Heather | Community Council | Eastern Shore, AL
Hi @Ukprash  - to check it's not a watch or firmware fault.
If you then get normal battery life of 5 days or more your watch is fine.
Try factory reset and then add one app at a time till you find the culprit. You won't lose any of your data. Mine did the same and now back to 5-6 days.
@MichaelPayne  - a factory reset has risks besides it can take time to set it up again and you may end up in a worse state than before.
There is normally a simple explanation as to excessive battery use, which is often excessive use of features not needed all the time.
I use my Just1Battey to detect battery drain. Found out that :
1. At night it uses a lot of battery. Snore detection(?)
2. At day when I use the GPS.
Some results:
120 minutes for 1%
15 minutes for 1%
Community Council MemberMario Dings | Rotterdam NL
Fitbit: Versa, Versa2, Sense. (Versa light) - Phone: Android. - Developer clockfaces.(Nederlands)
1. Right without question
Sense Activation 11/3/20\IPhone 12 Pro Max\SimpleClockPro Watch Face\Spigen Rugged Armor Pro Case/Band
