03-24-2022 06:06
03-24-2022 06:06
Dear All!
I already have this issue for a while and as I tried to find the solution, I also see that other people also have it already years before. But unfortunately I couldn't find the solution and the official support either misunderstood me or don't know the solution and give a basic answer.
I would like to use my Fitbit Sense in English but I'm living in Austria and I would like to keep my location service on, because some of the apps on my watch need it for functioning.
Anybody knows a solution which doesn't say that I have to switch off location and choose an English speaking country?
Thank you in advance!
03-24-2022 06:55
03-24-2022 06:55
Hi @Coolname82 - if you log into your settings here there are the options you can set.
Set Country Austria
Language by Country/Region - choose United Kingdom (English UK)
and remember to hit Submit at the bottom and then sync?
See if that gives you what you want.
03-24-2022 08:53
03-24-2022 08:53
Hi Guy_!
Thanks a lot! It seems it works. 😀
03-30-2022 00:57
03-30-2022 00:57
Hi!
do you have any idea why i have to change it every day and it doesn't stay how i saved it?
thank you!
Best Answer03-30-2022 01:07
03-30-2022 01:07
Hi @Coolname82 - are you by any chance using multiple devices to login?
Make sure after you made the change to logout of the web. And sync the watch.
Does it change systematically even without charging?
03-31-2022 00:14
03-31-2022 00:14
Hi Guy_!
I tried it, but today is again German even I logged out on the web and synced the watch. I didn't charge it.
I don't know what could be the problem, but it's very annoying.
Thanks for helping!
Best Answer03-31-2022 00:38
03-31-2022 00:38
@Coolname82 - thanks, there may be a few other places to change
It is working for me with a Sense and other Fitbit watches on a Samsung S9+, and it stays, so it is possible.
Just a matter of finding the right combination for you!
Best Answer03-31-2022 08:35
03-31-2022 08:35
Hi!
I will try the last 2 ones because the 1st cannot be. I need my location on.
Thank you!
Best Answer03-31-2022 10:26
03-31-2022 10:26
Actually @Coolname82 you should be able to set automatic location off.
It's different to having the phone being connected to GPS for location which is necessary.
