01-25-2021
16:33
08:06
WilsonFitbit
01-25-2021
16:33
08:06
WilsonFitbit
No matter the type of charger I use the Sense indicates a low charge signal! In addition the charge last two days max despite only being on when I turn my wrist! I want to love this watch but issues persist!
Best Answer01-25-2021 19:19
01-25-2021 19:19
I’ve seen some post on here about slow charge or low charge. It may be the cable if you’ve tried multiple bricks and multiple outlets. Have you tried a fast charge usb brick? Also make sure to clean all contact points on the watch back and charger.
If all else fails might be time to contact customer support.
i just turned the screen wake to manual from automatic when not in use. There are other ways to extend the battery life. I have a lot of features running constantly and just recharge frequently.
https://help.fitbit.com/articles/en_US/Help_article/2004.htm
Hope some of these suggestions help.
Best Answer01-26-2021 03:37
01-26-2021 03:37
Please use the high speed walk brick that you use with the phone.
As for battery life, do you want the extended SpO2? If not, then remove the SpO2 app from the sense
