01-14-2022
19:30
11:31
LizzyFitbit
01-14-2022
19:30
11:31
LizzyFitbit
its been exactly 1 year since I bought this watch and I noticed recently that the metal rim has changed to blue colour. Any idea why this is happening?
Best Answer01-15-2022 12:54 - edited 01-15-2022 13:01
Hi @AbhiVarma.
That's strange, it looks almost like an oily coating of some sort. Perhaps something has got onto the metal and reacted with it? I assume you have already tried cleaning it without any success?
Edit - -
A quick Google suggests such "blueing" can occur when stainless Steel is heated up, something to do with a thin layer of iron oxide forming. Some suggestions are to use vinegar to restore the metal, although I'd recommend you do some research before attempting anything.
I would also recommend contacting customer support before you attempt any self repairs, perhaps it will be covered under warranty.
01-20-2022 18:58 - edited 01-20-2022 18:58
Yeah even I read this on google, not sure how it happened.
Best Answer01-20-2022 20:06 - edited 01-20-2022 20:06
Try to look at the bright spot here, you have a one off patina sense. 😉
