08-17-2022 12:23
08-17-2022 12:23
My Fitbit is not counting the floors I climb. I go up and down the same stairs in my house, and I’m lucky if it counts one out of five times. I make sure I walk a bit before I go up the stairs, and I walk to the end of the hall before I go down the stairs The stairs come in two flights (split level), but they are close together and previous Fitbits have measured it accurately. Climbing stairs and setting a goal of 15 flights a day is a huge motivator for me, and it is very discouraging not to be able to count them.
Best Answer08-17-2022 12:42 - edited 08-17-2022 12:44
@ocanada73 I forget, it's 10 or 12 feet you have to go up continuously. No hesitation. I have to go up the basement steps, turn and go up the back landing steps, and raise my hand overhead at the top for best chance of floors at home.
08-17-2022 12:27
08-17-2022 12:27
Hi @ocanada73 only going up counts. You try restarting the device? With my old Blaze, I would get into the habit of waving when I reached the top of the stairs. Wonder if that would help you.
08-17-2022 12:33
08-17-2022 12:33
08-17-2022 14:37
08-17-2022 14:37
10. At least I'm not the only one waving @MarkMM
08-21-2022 12:31
08-21-2022 12:31
Holding my arm up with the Fitbit on it once I hit the top step, and leaving it up as I walk down the hall and back to the stairs to go down, works. But that’s pathetic. My last Fitbit counted those same sets of stairs as one floor, every time. They need to fix that!
Best Answer09-07-2022 12:19
09-07-2022 12:19
I have this same problem with my versa 3 not counting floors climbed. I’ve have 3 other fitbits (versas & others) over the years and all of them counted my steps climbed with no issue. I have messaged support several times, get told I’m being sent to a higher support person, then radio silence.
