03-01-2023
09:04
11:09
03-01-2023
09:04
11:09
My fitbit died two weeks ago. I contacted customer service and they sent me a new charging cable which didn't resolve the issue. The strange thing is that I had been around the block before with fitbit customer service in the past with this same issue. Instead of offering me a free charger cable which would have solved the problem I had a choice to either recieve an refurbished model, which I had two times and it didn't fix the problem of the fact that the battery drained after a day. So I went ahead and purchased a new model with charger cable which then charged my previous fitbit and the new one. Oh how I wish I hadn't purchased the new fitbit that's now dead. I wish I had waited to buy a new sense 2, which is what I want to do moving forward, but right now, I had an old but working fitbit and a new one under warranty that is now as dead as a doornail. If they are going to try and address the issue of the new one that's dead, the only option that makes any sense to me is to replace it with a sense 2 since I already have an existing sense from before that works okay even if I have to charge it every other day.
Best AnswerI would call Customer Support, explain to them your preference and see what they say. They may give you a discount on a new Sense 2 instead of a replacement Sense. The worst they can say is “no”!
