03-22-2022 01:06
03-22-2022 01:06
Hi,
My fitbit sense is not working since days, I contacted the customer support on 18th March, they even raised a case number for the same. But since then I have not heard from them. When I initiate their chat service and ask for an update, they say they will follow up.
Any idea on how to escalate this?
Regards
Achyuth
03-22-2022 04:51
03-22-2022 04:51
Hi @AchyuthB - the problem may not be with the watch but with the charging.
It needs to be clean and the charge cable and power source working.
Just in case, check How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
03-22-2022 06:22
03-22-2022 06:22
The charging is working well and good. The watch shows the fitbit logo, and nothing works. If I hold down the power button for 10 seconds, the watch vibrates once, and then shows the logo back again. I have done all the troubleshooting steps provided by the support team, no help.
-Achyuth
03-22-2022
06:44
03:04
03-22-2022
06:44
03:04
@AchyuthB- Probably best to contact Fitbit Support again and ask them to assist you with a factory reset.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
If it is still under warranty, 1 or 2 years depending on country law, and found faulty it may be better to take it to the shop for a new replacement, rather than accepting a refurbished replacement from Fitbit and dealing with sometimes drawn out return and shipping issues that may occu
03-22-2022 07:21
03-22-2022 07:21
Hi,
Thanks for so much for your advice.
I bought it on "Wed, Oct 20, 2021" from their website fitbit.com itself., so I believe this falls under warrenty. I have the Order Confirmation email with other details.
Since you are asking me to replace it from the shop, I am thinking if I did a mistake by buying it from their website. Would they really send a refurbished one?
-Achyuth
03-22-2022 07:30
03-23-2022 10:12
03-23-2022 10:12
Hi,
They are gonna send me another one, this is the what they have mentioned
"Replacement, New, Sense Graphite Stainless Pebble"
Will wait and see...
-Achyuth
04-11-2022 05:30
04-11-2022 05:30
Hi,
Sorry for the delayed reply. I received a new fitbit sense, it is working perfectly fine.
Thank you Fitbit.
-Achyuth
