My iPhone doesn't give an option to allow calendar to Fitbit
I would like to have a connection between my calendar in my Iphone and my Fitbit Sense, but when I want to allow this in settings there is no option to give  the calender acces to my Fitbit...
My wi-fi doesn't connect either, maybe that has something to do with it?
3 REPLIES 3
For WiFi to connect, the tracker needs to be plugged in and charging, since this is the only time that WiFi is turned on.
Is your WiFi the 2.4 ghz?
What error do you get?
I'm not sure about iOS but in android, permissions are set through the phones settings.
Of course through the fitbit app - Sense notification settings when turning on the calender. The OS will ask you for permission to allow fitbit to have access.
Yes, I plugged my Fitbit to the charger when trying to connect, unlucky.
I get a red cross all the time, and if it connects with luck, the Wi-Fi is disconnected again after 5 seconds.
Where can i check if my Wi-Fi is 24ghz?
Thanks, that helped, my calendar is connected now 😄
This is usually found on your router. Or use a browser to log into your routers interface.
Many of today's routers have both 2.4 & 5.0.
Alternatively go to this FCC page and enter the FCC ID of your router.
