04-16-2021 04:52
04-16-2021 04:52
My sense hasn’t been able to sync for 5 days. Finally I tried to unpair it and now it won’t pair at all. I tried calling customer service and that doesn’t work either. Any suggestions?
04-16-2021 05:07
04-16-2021 05:07
Me neither!! Is it a system wide problem?
04-16-2021 05:25
04-16-2021 05:25
Happening to me too 💁🏻:female_sign:
04-16-2021 08:44
04-16-2021 08:44
If it been 5 days you already lost your data it only holds for 3 days so in the app itself clik your icon top left corner & 4 rows down click your sense icon now top right should be trash can icon clik it to unpair not sure exactly after that where it says forget this sense your basically dropping the entire sense from the app now you will have to start over and re set up your sense all over again make sure to do this with a cell phone it will ask you to put in the 4 digit code again and this should reset up every thing and you should be able to sync from there.
04-17-2021 20:43
04-17-2021 20:43
For a week now my Fitbit sense has been unable to sync, then won’t pair and now clock face has vanished with 70% battery life. Do I have a defective devise or is something else going on. My sense is under 4 months old
Best Answer04-17-2021 20:45
04-17-2021 20:45
Won’t pair either.
04-17-2021 20:48
04-17-2021 20:48
April 2021. Sense won’t pair and now clock face has disappeared. Battery life is good. Tried calling customer service and that won’t go thru either. Anyone else having problems
04-17-2021 21:15
04-17-2021 21:15
Fitbit customer support is doing their best, but right now be prepared for longer wait times. Please be patient. Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
Best Answer04-19-2021 13:37
04-19-2021 13:37
The USA phone number takes you to a call center than when you touch ( in my case) 4 the phone call doesn’t recognize that you’ve tried to move on in their program. Finally got into live chat and had to reboot Fitbit and my phone. Took a LONG time for Fitbit to pair but after 8 days I finally have phone and Fitbit working again
Best Answer04-19-2021 14:51
04-19-2021 14:51
me too!! sounds like system wide problem. customer service could not help me either
Best Answer04-19-2021 15:31
04-19-2021 15:31
just finished with customer service! you have to go to Settings on the watch, reset to factory settings and then when app starts pairing process hit Bluetooth, not WiFi! mine is not pairing. good luck.
Best Answer04-19-2021 15:32
04-19-2021 15:32
sorry mine is NOW pairing. yeh!
