12-29-2020 04:48
12-29-2020 04:48
My phone app is correct, but the Sense has a different goal. I can't figure out where/how to correct this. Do my goals not sync? Honestly, I can't find my goal settings in either the phone, Sense, or the PC. With this and the other issues I'm becoming seriously frustrated with this thing.
Best Answer12-29-2020 06:24
12-29-2020 06:24
I think I can help you out. I was changing some of my goals yesterday.
On the phone, go to the fitbit app and press on your photo (top left hand corner). This will bring up your account. Scroll down to "Activity & Wellness". Then go to "Daily Activity". You can change all your goals there.
In fitbit.com, within your dashboard, you hover the pointer within the "Today" box (where your goals are shown). A Settings wheel will appear under the box. Click on it. This will bring you to your daily and weekly goals.
Hope this helps....
12-29-2020 06:24
12-29-2020 06:24
Hope this helps....
12-29-2020 07:16
12-29-2020 07:16
@Mont-Sly THANK YOU!! I had some trouble with the dashboard, could only find my weekly goals. That's fine, I can do math. LOL!
I got the phone corrected. The Sense is still wrong, but hopefully that will correct after syncing.
I appreciate your help with this more than you know!
