-Latest Fitbit app
-Samsung Note 10+
-Android 11
New Sense loses connection and ability to sync after firmware update during initial setup.
I have attempted all suggested remedies here and on the faq pages from the simple bluetooth re-pairing to app reinstall and factory reset on device.
Any other ideas?
Thanks
09:21
07:07
01-24-2021
09:21
07:07
Probably best to contact Fitbit Support directly. They may be able to help you.
Your phone is not on the compatible phone list
So there could be issues following the update where it was working before to discuss with them
09:21
07:07
01-24-2021
09:21
07:07
09:21
07:08
01-25-2021
09:21
07:08
Hello @Nckeg Welcome to the Community Forums! @Guy_ @Rich_Laue Your input is very appreciated guys!
@Nckeg I was informed by the Support Team that you contacted them yesterday and they have provided assistance. Since you have received assistance from them, I suggest you to update your case or get in contact with them one more time if you require further assistance or if you have any additional questions.
Have a wonderful day!
Best AnswerThanks for pointing me to the compatible device list! After your response I did converse with online support and they agreed that may be the issue.
As it stands my Sense will not work with my Note 10+ however it does function properly with my old S7 edge. So I'll have to use it for the time being and hopefully one day it might work with my Note.
05:05
07:07
