04-25-2021 21:26
04-25-2021 21:26
I've just bought a non sense or in this case over sense , it's recording too many steps , I was on my bike for a short time just cruising and it recorded over 11k steps which is impossible , I paid a lot of money :money_with_wings: and it just does not work and if any one sujests that cruising on my road bike burns calories tell that to my waist line.
Best Answer04-26-2021 00:59
04-26-2021 00:59
Fitbit devices won't disable step detection for non-steps activities. When cycling, it results in adding steps due to uneven road surface, bumps or simply shaky ride. Steps are more like a side effect here. It's the way Fitbit devices are designed to work.
Best Answer04-26-2021 03:16
04-26-2021 03:16
Best Answer04-26-2021 03:22
04-26-2021 03:22
And an icon othe Watch to select the type of movement?
Best Answer04-26-2021 03:59
04-26-2021 03:59
@Stephenp123 same, uneven surface and the shaky ride are interpreted as steps. It doesn't matter whether it's bike, motorbike, car or horse. It works all the same for step detection.
04-26-2021 14:55
04-26-2021 14:55
