01-26-2023 14:44 - edited 01-26-2023 15:48
Getting connection.error when trying to answer a call on the sense. I get the red phone the green phone incoming call but when I tap on the green answer it says connecting then I get the error message below
“Connection Error
There’s something wrong with your connection.
take call on your phone
I did not have this problem in the past.
I shut off phone and restarted the watch.
any ideas. Turned off and back on Bluetooth.
check on writs call setup. it is obviously working as the call is hitting the sense and I’m getting the option to answer. It just will not connect.
Best Answer01-26-2023 15:53 - edited 01-26-2023 15:55
Disregard…….
I tapped on sense controls in the list of bluetooth
devises and then forget this device.
I then set back up on wrist calls.
All is working well.
