Option to add more than one device to your Fitbit account
Fitbit needs to modify, update or re-engineer the app in order to be able to save more than one watch in your profile and then select one watch at a time from the watches you own. As it is, one watch must be removed before another can be added. I own two watches and it's a PITA to have to do it this way. Come on Fitbit, step up to the plate!
2 REPLIES 2
Hi @tony2scallops  - you could always setup 2 accounts, then you logo6of one and into the other with one watch on each account.
If you adopt that approach you might want to install for Ionic, Versa and Sense watches the SimpleCheckUp app which enables you to see directly on the watch when you last synced.
Yes, I could do that but then the stats from both (or more) watches would not be combined in one single dashboard. I would also have to pay for 2 premium subscriptions to get the same information I do now. Thanks for the suggestion but at least for me, not a workable solution. Fitbit needs to address this with an app update.
