07-30-2021
19:59
04:37
WilsonFitbit
07-30-2021
19:59
04:37
WilsonFitbit
There's no Pandora button under Media
07-31-2021 04:39
07-31-2021 04:39
Hello @jenmayodc. Welcome to the community forums!
Thank you for this information. Are you referring that Pandora is not appearing in the Fitbit App? In the meantime, I'd recommend visiting this help article about how to set up and troubleshoot apps on your Fitbit device: How do I set up and troubleshoot apps on my Fitbit device?
You can also find detailed information about Pandora here: How do I listen to Pandora stations on my Fitbit watch?
Hope this helps.
07-31-2021 07:53
07-31-2021 07:53
Hi! I already did all that. When I go to the Fitbit app to do this step:
"Go back to the dashboard and tap Media then Pandora"
There is NO Pandora option under Media.
Best Answer07-31-2021 12:54
07-31-2021 12:54
Could it be because I am in PR, which is a US territory but not a state? I mean, that makes no sense because I use Pandora in my car, at home, on the phone.....That would be really stupid.
If that's the case, can I at least control Pandora (playing on my phone) from the Fitbit watch?
Best Answer07-31-2021 12:56
07-31-2021 12:56
Also, if that's what's happening.....what will happen when I go back stateside? I just travel a lot back and forth, so not sure how that would work.
Fitbit needs to fix this ASAP!!!!
