05-10-2022 11:26
05-10-2022 11:26
Hi,
I just got a sense upgrading from a charge 2, my mind is blown!! There are 5 saved clock faces I don’t know how they got there but I would like to save the ones I have chosen. How do I delete and save a new clock face?
Thanks a Billion!!
05-10-2022 14:30
05-10-2022 14:30
I think Fitbit just chose 5 faces 'by Fitbit' to fill those up, but easily replaced.
First, I suggest write down the names of any you want to keep in case you accidentally delete it later on - can be hard to find again.
On phone app:
Profile Pic > Sense > Gallery shows the clocks currently selected. Tap any you don't want, and at the bottom is selection "Remove clock face"; then to find more to add, either 'Discover more' on that screen, or 'Clocks' tab at top.
05-10-2022 14:30
05-10-2022 14:30
On phone app:
05-10-2022 19:58
05-10-2022 19:58
Hi @HarleenQuinzel - @JohnnyRow makes an excellent point to keep a log of clock faces, as it can be quite difficult to find them again.
Also note you can't remove the active clock face, this is to make sure you keep at least one clock face on the watch for it to work.
05-11-2022 05:39
05-11-2022 05:39
Thank you soooo much for your help and suggestions. That is a great, I was having trouble finding clock faces I had just chosen! Thanks
again!!
-Mary
05-11-2022 05:43
05-11-2022 05:43
Hi Guy, I totally agree with you! @JohnnyRow has a great system. I have been scrolling through clock faces like crazy looking for one that I had a few minutes ago!! Thank you for replying to my post!! -Mary
