04-19-2023
01:08
06:14
04-19-2023
01:08
06:14
Reminder to move not working - it's on it the settings. Any ideas gratefully received. Thanks
Best Answer04-19-2023 06:17 - edited 09-14-2023 04:07
Hi there, @KatePz. Thanks for stopping by in the Fitbit Community Forums.
While reading your post I was wondering if the reminders to move are the only notifications not coming through? If you're missing any other notification, please make sure that sleep mode or DND are not enabled on your Versa 3. When the sleep mode setting is on:
When the do not disturb setting is on:
For more information, see How do I navigate my Fitbit device?
If the above doesn't describe your issue, I suggest restarting your Fitbit device by following these steps.
In none of the above works, please try setting up your Sense as a new device in your account if you're still having the same problem. Then repeat the restart procedure and set up notifications to check if they're working properly.
