10-07-2020 07:21
10-07-2020 07:21
Is there a way to reset the temperature baseline on the Sense. The first 3 days I wore it, the sense did what is was supposed to do and set my baseline temp. However my body was super hot. I happened to be running a high temp during those 3 days and ended up in the hospital actually with a perforated bowel. I'm back home now, and the temp is dropping like a rock from my super high baseline. Is there a way to start it over from scratch and get a new baseline, now that I'm fever free?
Best Answer10-07-2020 07:48
10-07-2020 07:48
Hi sportionary. Hope you are well and recovering quickly. If you enter the Health Metrics tile on the App, scroll down to "Learn More" under the Skin Temperature section. Tap "See today's skin temp" and at the top of the screen is the symbol "+". This allows you to manually enter a core temp.
Hope this solves this for you. Be well.
10-07-2020 07:53
10-07-2020 07:53
You can remove temperature records for selected days in the app (through the gear icon in top-right corner on the Temperature tab). That should do the trick quickly.
Or the app explains that "Fitbit app uses up to 30 nights of data to adjust you baseline temperature." So after a month, your high temp days will no longer contribute to the baseline temp calculation.
