I had the Fitbit Versa 2, but the band attachment broke so I ordered the Sense. I put both watches on my wrist and they show two different heart rates, the Sense is about 5 beats per minute higher than the Versa 2. Anyone else have this problem?
Hi @Kallybaby - the Sense only provides an accurate heart rate when you are still. As the resting heart rate is done when you should be still they should be about the same. What it could mean is you are less still at night and the Sense is not getting an accurate reading. The real time readings will certainly not compare, the Versa 2 being the one of reference.
