12-02-2020 04:53
12-02-2020 04:53
I struggle with my new Sense. All is updated, I enabled all notifications both from the app and from the Android phone I'm using. I had to remove sense and sense controls from the Bluetooth devices and it was horror trying to connect them again.
Even if I enabled all the notification, the app is telling me that I have to restart my phone because notifications are "off". I restarted several times and I have the same issue. Also with the sync sometimes.
Also, I cannot add Alexa as an app on the watch even if I want to remove the wallet... Alexa works only on my phone. I cannot connect to Spotify and I cannot Listen music on watch without connecting other devices that he obsiously doesn't see...
Help! Thx!
Brigitte
Best Answer12-02-2020 05:30
12-02-2020 05:30
I have turned Bluetooth on and off and restarted my phone a dozen times, and Uninstalled the app nothing is working it won't sync. Have you been able to reconnect? I see my last sync was about the time of an app update last night
12-02-2020 05:35
12-02-2020 05:35
Best Answer12-02-2020 07:17
12-02-2020 07:17
I'm so disgusted with my Sense I'm ready to send it back. I can't get deezer to work, I can't get my airpods to pair, I'm not able to reply to texts, Spotify doesn't work on the Sense, I'm really disappointed. Anyone have any idea how to get any of these things to work. I've worked on these things for two days and am now ready to return the watch.
