@dwjoyner it is not a button that actually moves so it will not be stuck in down or up position. It is an indent in the watch casing. To use the button you cover it with a finger tip. See https://community.fitbit.com/t5/Sense/How-to-use-The-Button/m-p/4498914#M1547
Best Answer@dwjoyner it is not a button that actually moves so it will not be stuck in down or up position. It is an indent in the watch casing. To use the button you cover it with a finger tip. See https://community.fitbit.com/t5/Sense/How-to-use-The-Button/m-p/4498914#M1547
