10-29-2025
17:10
10:20
DavidFitbit
10-29-2025
17:10
10:20
DavidFitbit
I have attempted to reboot multiple times and unable to make any process. I have read all of the forum solutions and none of them work.
Hi @janellevdvelde - rebooting to the Fitbit logo is generally terminal as it is probably impossible to start a factory reset before it reboots.
You could try letting it run down completely so that a long button press does nothing at all, then charging for 30 minutes and trying a factory reset with the button while charging.
It is unlikely to work because the watch is in an error state.
Hi @Guy_ and @janellevdvelde. Welcome to the Fitbit Community! It's great to have you here!
Let me help you with the Recurring loop issue you've been experiencing with your Sense. I appreciate the time you have spent in the research towards the resolution of this issue. Thank you @Guy_ for your suggestions.
Usually, a factory reset is an invasive procedure that may be attempted if a terminal situation arrives with the device as @Guy_ says. Invasive because you'll need to set up the device from the beginning and all apps that have already been installed on the device will be deleted.
In order to better understand the loop you are experiencing, may you describe in detail the loop you are experiencing so we can together offer a more precise solution? I mean, sometimes the loop includes a Fitbit logo, but sometimes it may be a little different. Thanks in advance.
Hi @janellevdvelde, thank you for your response.
I'm glad to hear that you were able to resolve your situation by returning your device to the retailer.
It was a pleasure to help you. I remain at your disposition if you need any further information.
The main goal of the community is to provide you with user-friendly resources so you can troubleshoot on your own.
Feel free to come back and participate in the community. That's how forums grow!
