11-19-2020
09:36
15:37
KateFitbit
11-19-2020
09:36
15:37
KateFitbit
Update 12/11/2020: An update OS 5.1.1 (44.128.4.17) is now available to all customers.
Update 12/8/2020: An update OS 5.1.1 (44.128.4.17) is currently in progress. Full release notes can be found here.
Update 11/25/2020: OS 5.1 (44.128.4.15) is now be available to all customers. If you have any difficulty updating, make sure you are following the directions in this article, and then provide as many specific details as possible in your post so that we can assist.
Announcing the release of Fitbit OS Firmware Update 5.1 (44.128.4.15)!
We release firmware updates to all customers in phases. The update will be available to everyone soon, and a banner will appear in the app when you can install the update. If you don’t see the banner yet, check the app again later.
Important Note: You will need to be on the latest app: iOS 3.34 or Android 3.34.1 in order to view the latest features. Please update your app.
*Firmware releases are not distributed based on region or location and can reach anyone no matter where you reside. We do not recommend performing a factory reset to force the update to your device as your data will be lost and you may not get the update. Please be patient and wait until you see the update banner inside of the Fitbit app to begin the firmware download.
WHAT’S NEW AND FIXED
View your device’s activation date, which is the day your device’s warranty begins. The activation date is the day you set up your device.
Use Google Assistant on Fitbit Sense and Fitbit Versa 3. For more information, see How do I use a voice assistant on my Fitbit smartwatch?
Use the built-in speaker and microphone in Fitbit Sense and Fitbit Versa 3 to take calls from your wrist. For more information, see How do I take on-wrist phone calls with my Fitbit smartwatch?
HOW DO I UPDATE?
Step by step instructions for updating your Sense can be found here.
I recommend updating your Sense over a home Wi-Fi network as this can greatly reduce the time it can take to get set up. For more information on connecting your Sense to Wi-Fi, check out this article.
If you run into any trouble updating, review these troubleshooting tips.
We look forward to hearing your thoughts!
11-23-2020 10:45
11-23-2020 10:45
Google assistent is what i was waiting for.. i dont know . Fit it had its charms for sure.. garmin is very clean and professional but a bit older wheb it comes to watch os and smart functions.. so the perfect watch isnt out there i guess
Best Answer11-23-2020 10:50
11-23-2020 10:50
Got pop-up on my phone telling me to go to Fitbit app and download new update. Tried everything from checking for new update in the app, to playstore and uninstalling app and reinstalling. Nothing worked. So, I come on here and I see that many people cannot get the app. I am not sure what is going on. I have received this pop-up twice and it does not have an installation button. It tells me to download from the app.
Am I missing something?
11-23-2020 10:56
11-23-2020 10:56
I saw the same thing. I don't know why Fitbit is pushing the "update" message if we can't actually update.
Best Answer11-23-2020 10:57
11-23-2020 10:57
Did you put your watch on charger to update?
Best Answer11-23-2020 11:38
11-23-2020 11:38
Yes, left it on for about an hour. Still will not update. Also restarted Sense while it was plugged into charger and still nothing.
Best Answer11-23-2020 12:53
11-23-2020 12:53
@Deechte You can increase and decrease the volume on the device itself, but the maximum isn't very loud. In most instances you'll need to have the device up against your ear.
11-23-2020 13:02
11-23-2020 13:02
OK thanks. The volume up button on your phone doesn't increase the upper limit then?
11-23-2020 13:38
11-23-2020 13:38
I got a email to update watch but having trouble ?
Best Answer11-23-2020 13:54 - edited 11-23-2020 13:54
Got me thinking "Should I return my Active Watch 2 and keep the Sense?" I don't really know. Calls on the Active Watch 2 sounded good for a watch to me plus you can make and take calls. And the better notifications. So I don't know if I'll keep this Sense or not.. If I would've had to pay full price for the Sense it would definitely be going back. It's 2020 and the Flagship Sense can do what? But I was lucky enough to be able to get two for the price of one.
Best Answer11-23-2020 14:09
11-23-2020 14:09
@Deechte I haven't tried it yet for a call, but I will give it a go next time and report back. Obviously Alexa's volume can only be controlled on the device itself, and maximum isn't great.
Best Answer11-23-2020 17:40
11-23-2020 17:40
Yeah... Fitbit doesn't seem to understand how to rollout updates or when to send emails properly. They are doing some staged rollout crap and you can't force the update by telling it to check. Constantly disappointing it's users is what they are best at.
11-24-2020 01:13
11-24-2020 01:13
@Beezy1978 wrote:Yes, the HR is *very* accurate now. This was almost reason for me to return mine, so I’m glad it righted itself.
Give her another go!
That is good to hear. The main reason I got it.
I don't use my phone for calls, why would I want it on my watch!
Everyone else, chill this is how fitbit has always rolled out its updates.
11-24-2020 02:33
11-24-2020 02:33
I don't understand why it takes that long to release an update, Apple, Google, Garmin...they announce an update and then everybody can get it. There is absolutely no reason fitbit can not do the same. To role this out in waves to make sure there are no major issues indicates very little trust in their firmware.
11-24-2020 03:41
11-24-2020 03:41
It's 2020 and we are waiting at least 1 week for a software update ... A SOFTWARE UPDATE, lol.
And there is no possibility to update your device manually by downloading the firmare update to your computer and update via usb ... in 2020...
11-24-2020 04:46
11-24-2020 04:46
Even their SpO2 value takes a whole night +1hr of processing, no suprises that patches take months to reach everyone.
11-24-2020 05:58
11-24-2020 05:58
I am growing impacient... Where is the update...?
11-24-2020 11:01
11-24-2020 11:01
You'll need to open app & Select sense & the Banner is suppose to show there! That's how it worked on my Versa 2 & according everything I've read it's the same! I'm still waiting for it to show on mine! Can't wait to get it tho! Like to see it soon!
11-24-2020 11:06
11-24-2020 11:06
You'll get it eventually, lots of us waiting to get it! Fitbit does a slow roll out! My fitbit Versa 2 was suppose to get update when first got it took couple weeks! So I'm thinking the roll out for Sense will take that long also! The techs I've talked to say it is rolling out in US but it will take several days before everyone sees it! Don't know how it's determined who gets first or whether it's based on purchase date or what, No one will answer that question!
Best Answer11-24-2020 11:13
11-24-2020 11:13
Would like to use it as a blood pressure monitor, but where do I go or which app do I need to download?
Thanks in advance
PS: 27hrs with it and loving it
11-24-2020 11:32 - edited 11-24-2020 11:32
Fully agree Neil. My main reason for buying the Sense is tracking my exercises and health so hr accuracy is key. No problem to wait a few days or more, as long as it is fixed!
