Hi, Just got a fitbit sense. Should I sync up my google fit data to fit bit, and then use the fitbit app. Or should I go the other way and sync my data (continuously) from fitbit to google fit and use Google fit?
Has anyone done either over sustained period? How do you rate either app?
Thanks
Q
Best AnswerI'd sync it lnlh with the Fitbit app.
one cruise ship at a time!
Best AnswerSense and any Fitbit tracker doesn't sync directly to Google Fit and actually doesn't even connect to Google Fit.
What it does is to sync with Fitbit app (and you can't do differently) and then, if you like, running a third part application like Fittofit, to export the data to Google Fit.
I would say that, owning a Fitbit, it is better to stick with Fitbit app.
