04-14-2022 12:31
04-14-2022 12:31
Hi there. My Fitbit Sense (purchased on release 2020) has completely died. I wore it a day ago when going swimming. It's been in water before without issue.
When I went to the gym, the device had about an 85% charge. I wore it into the pool, swam for about 25 minutes, stopped in the sauna for about 3-4 minutes, then saw that it had totally died.
When I got home, I put it on its charger. A few hours later, I went to check its charge and realized the thing was blazing hot - I nearly burned my hand - so I removed it from the charger. It's now cooled down, but no amount of fidgeting/button pushing can get it to turn back on.
Is it possible that it completely shorted out from having gone into a hot room after being submerged? That shouldn't have caused anything. I also admit that I didn't look at it before entering the sauna; it might have died in the pool.
Has this happened to anyone else and is it salvageable?
Best Answer04-14-2022 17:26
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
04-14-2022 17:26
@SunsetRunner I would think water has leaked into your Sense, based on the fact it became "burning hot", indicating a short circuit.
04-14-2022 17:59 - edited 04-14-2022 18:02
I think the sauna may be outside the operating temperature. See page 76
https://help.fitbit.com/manuals/manual_sense_en_US.pdf#page76
04-14-2022 19:49
04-14-2022 19:49
@Clove6060 , I don't see why ourtside operating temp should "kill" the device. It's like when you forget your fun on the dashboard on a warm summer day. It comes back to life when temp drops. Besides, it doesn't explain the short circuit.
04-14-2022 20:05 - edited 04-14-2022 20:06
I can imagine a steam room where high heat compromises the glue/seal and the sauna humidity/moisture invades the watch. Not a good combo in my mind.
Most saunas are 150-175 Degrees Fahrenheit or higher and Infrared saunas are typically 120-130 Fahrenheit.
04-15-2022 11:30
04-15-2022 11:30
Hi, @SunsetRunner welcome, I think the advice about the sauna temperature might be right. You could talk to "Customer Support" here to get their thoughts. I recommend you use the chat facility or phone for a prompt response.
I hope this helps
Cheers
Gr4ndp4 | UK
04-15-2022 11:56
04-15-2022 11:56
Thanks everyone. It's definitely a short circuit, not fixable. I'll contact Customer Support to determine what might have happened and make sure not to let that happen with another model.
Best Answer06-26-2022 16:27
06-26-2022 16:27
This happened to me too! It was fully charged, then i went swimming for 20 mins and it died so I tried to charge it and it was burning hot. I disconnected it from the charger as soon as i felt the temperature and now a day later I've tried charging it again and it is still completely dead after 5 hours on the charger.
Best Answer06-27-2022 00:37
06-27-2022 00:37
Hi, @Mabel2 you should not attempt to charge your Sense, Contact Customer Support for assistance
Cheers
Gr4ndp4 | UK
