My Sense is about a few months old. It works very well and really no problems. My Sense is updated with latest firmware and latest IOS Application.
About once a week the sense battery is dead at various times night, day etc. Sort of aggravating. For example, last night the battery read 84%. About four hours later the sense was dead as I wear it. The app on my IOS device was not running. I put the device on the charger and the sense started and registered 0 % and charged normally and works fine. After charging it will register 100% charge and work as normal for several days. Then it will be dead again. As I stated this happens about once a week. Any ideas. Thanks in advance for any assistance.
Hi, Have a look on here how others have dealt with battery draining problems - One thing to try is to turn off the phone's Bluetooth at night.
Snore detection AND SpO2 will cause quite a drain at night. To remove SpO2, remove the SpO2 tracker app and don't use an SpO2 watch face, and try with Snore detection off.
However the erratic behaviour seems a little strange.
Another thing is to make sure sleep is enabled at night [it can be set in watching settings to come on during the night] this will dim the screen and stop the display from waking on movement.
More here Can I extend my Fitbit device's battery life?
