I went on my usual run this morning, the first time I have run with my Sense since getting it. The watch seemed to follow the run correctly, and notified me that I had achieved the correct number of active minutes. But when I ended the run, and the watch downloaded to the app, it cut about three miles off the run. Then when I looked at the map of the workout, it had the entire track on there, with a weird squiggle through the middle like it had lost GPS or something and reset. Has anyone else seen this?
Best AnswerWell that is really annoying. The map showed the entire route, with average speeds throughout, then just because it lost GPS at the very end it screwed up the entire thing?
Best AnswerWhen it loses gps, it should fall back to the users stride for distance calculations.
Normally when gps is lost, the user will see a straight line, your wiggles point to possibly interference in the signals causing a delay in the timing.
