Hello! This might be a strange question, but I am wondering if the Snore report can mistake teeth grinding for snoring since the microphone is on? I'm not saying I don't snore, I'm just curious if it can get the two confused. I do grind my teeth pretty bad. I have done this my entire life.
Best AnswerHi, @etryz, welcome to the community, there's a long section in this article on "Snore Report" How do I track my sleep with my Fitbit device? The noise source cant be identified, is it your partner? or the dog? From a practical point of view, the noise is detected by the microphone in your "Sense" so it is in effect air vibration. How loud teeth grinding is may not be easy to determine by the grinder as the sound reaches them by a different route. If you do have elevated teeth grinding you may want to consult your dentist.
Cheers
Gr4ndp4 | UK
