11-23-2020 14:36
11-23-2020 14:36
The band on the Sense appears to be difficult to adjust/tighten as the end of the strap is tucked between the wrist and the band itself. Seems counter-intuitive and opposite every strap that I've owned in the past 50 yrs.Sometimes if it's not broken; don't try to fix it.
11-25-2020 14:36
11-25-2020 14:36
@QFITGLL, I've found just the opposite with the Sense band. For me, it seems very easy to adjust the size and tuck the end of the band in behind the buckle. Took a little getting used to the first couple times, but after that is was very easy.
Best Answer11-25-2020 17:30
11-25-2020 17:30
I did not like it at first, but now I simply wear it a little looser than other watch straps and with the end tucked in it fits fine.
