06-24-2021
17:15
14:07
LizzyFitbit
06-24-2021
17:15
14:07
LizzyFitbit
My Sense added over 11k steps between 4:30 am and 4:45 am while I was sleeping. I am using a Samsung Note 8 and have fully restarted my phone and the Sense. Both are fully updated. I have also uninstalled and reinstalled the app and the steps still show incorrectly.
I dont know how to fix this and its messing with the data in my Lose It app. Help please!
Moderator Edit: Formatting
14:19
04:07
06-28-2021
14:19
04:07
Hi @morelikedeathly. Welcome om board. @Guy_ Thanks for your suggestions.
@morelikedeathly Thanks for every step tried prior to posting. I understand how much this is affecting your overall data and I'm sorry for this inconvenience. While this shouldn't be happening, may I know if you have MobileTrack setup in the Fitbit app? MobileTrack is a feature that records basic stats such as steps using your phone's sensors if you don't have a Fitbit device available. If there was a fan or anything buzzing nearby, or if your phone was vibrating during that time, that might have caused your watch to records steps during that time.
Assuming this applies to you, please give a try to the following steps:
Currently there isn't an option to delete the steps that have already been synced. However, you can log a non-step-based activity such as driving to override those steps.
06-26-2021 06:06
06-26-2021 06:06
Note to self: must stop the sleep walking!
Probably best to contact Fitbit Support directly. They may be able to help you.
14:19
04:07
06-28-2021
14:19
04:07
04-29-2022 02:47
04-29-2022 02:47
This has happened to me recently my fitbit automatically turned on mobile tracker but there's some sort of glitch where it adds thousands of steps while sitting or sleeping ..to alter your steps and get a correct daily reading you need to unpaired the mobile tracker and then where the added steps have been added take a note of the time and duration and then go to the exercise section and add that time and duration as driving it will then wipe the extra steps off and give you what you've actually done that day
Hope this helps
05-04-2022
13:00
07:09
05-04-2022
13:00
07:09
Hi there, @Kel93.
Thanks for your efforts while working on this matter, as well as sharing the steps that worked for you. I'm glad you sorted this out and I'm sure your post will help other members experiencing similar issues. In case you have some spare time, I’d like to invite you to visit our Health & Wellness board where you can share your story and find great tips to reach your goals.
