12-24-2022 05:26
12-24-2022 05:26
I’ll set my alarm before midnight and it says tomorrow. But then in the morning my alarm doesn’t go off. When I check my alarms it still says tomorrow in the morning. Essentially my alarms are never going off in the mornings anymore. I’ve checked for updates, resynced, deleted alarms and created new ones. And reset my Fitbit. Any help would be appreciated. Thanks.
Best Answer12-24-2022 07:31
12-24-2022 07:31
Hi @Corey9 - it's quite easy to set an alarm for tomorrow and in exiting turn it off.
Go back into alarms and make sure that it is not red (turned off).
Also try restarting the watch How do I restart my Fitbit device?
Best Answer12-28-2022 22:36
12-28-2022 22:36
No I have tried resetting the watch, and the alarms are still yellow. I’ve even tried setting an alarm for 1-2 minutes away, then the time will pass and when I reopen the alarm instead of saying today it will still be yellow but now say tomorrow.
Best Answer12-28-2022 23:09
03-31-2023 13:16
03-31-2023 13:16
Hi! I’m having this exact issue, did you manage to solve it?
Best Answer04-03-2023 14:23
04-03-2023 14:23
We're having the same issue with my wife's Sense 2 watch. She just upgrading from a Versa 2 but needs the alarms to work to get her up in the morning for work. This is a serious bug that many people, are reporting and it's not getting fixed.
Best Answer04-03-2023 14:33
04-03-2023 14:33
I actually solved the issue by updating my tracker within the app. Seemed to solve it so give that a go!
Best Answer04-03-2023 18:41
04-03-2023 18:41
Hi, just may be try the watch in 24hr mode, there could be problems with 12hr mode.
Best Answer04-05-2023 14:16
04-05-2023 14:16
