I just got my new Fitbit Sense yesterday. I have Premium and used the code to log into the Calm App. It says in the details from Fitbit that:
Data on your wrist that shows your body’s response to content. See the effect a Calm session has on your heart rate and EDA responses on Fitbit Sense after a Guided Session. You can also access the information in the Fitbit mobile app in the Mindfulness section.
I took one of the Calm guided sessions this morning but it doesn't show up anywhere on my fitbit, I looked in the Mindfulness session but it doesn't recognise that I have done any activity today.
Am I missing something? It sounded as though the Calm & Fitbit apps would link in some way, but seems this is not the case?
It does not migrate. After a Calm session you would need to do an EDA quick scan.
https://support.calm.com/hc/en-us/articles/4407832075163-Calm-with-Fitbit-Sense
Best AnswerMany thanks - so what does it mean when Fitbit says 'You can also access the information in the Fitbit mobile app in the Mindfulness section.'?
You're talking about this?
It is a little confusing in the post because it makes it sound like there's some kind of integration but I think that sentence is in regards to the EDA scam information.
