07-02-2021 20:38
07-02-2021 20:38
Sense app doesn't connect to wifi, thus not allowing access to administration of Sense apps.
Drops connections to Spotify app. And due to inability to connect to wifi I can not re-login in.
These losses in capabilities and use has reduced my Sense into a glorified pedometer.
07-06-2021 11:42
07-06-2021 11:42
Hi, @Sharkdancer , welcome to the community, you may find Why won't my Fitbit watch connect to Wi-Fi? provides you with the opportunity to review your settings and resolve your problem. If you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
Best Answer07-06-2021 11:48
07-06-2021 11:48
Best Answer07-06-2021 11:52
07-06-2021 11:52
Hi, @Sharkdancer , thanks for your update, this does not seem to be a common issue, it used to work for you, I suggest you review your settings. check out the permissions in your Fitbit app and review your wifi settings on your phone.
Cheers
Gr4ndp4 | UK
