03-22-2021
06:56
14:06
LizzyFitbit
03-22-2021
06:56
14:06
LizzyFitbit
I've had my Sense for about 6 months now and it's never behaved like this before. I've not been able to get it to charge for the past 3 days. Yesterday, it began displaying a message which reads "Fitbit device is operating below temperature, please warm it up to continue." For context, I live in central Florida. It's not like I'm a northern state where the temperatures are drastically cold. Naturally, the first time I saw this message, I put it back on my wrist for 10-15 minutes assuming my body heat is a sufficient heat source, but when I returned it to the charge, I got the same message.
14:19
03:33
03-23-2021
14:19
03:33
Hi @brwneyedbrndi Welcome to the Community Forums.
Thanks for bringing this to our attention. This is odd and while the environment was wasn't too cold, do you recall if your Sense was placed nearby something that was cold such as a cooler or A/C? If not and your watch is still not charging, I'd suggest you to give a try to the troubleshooting tips described in this help article and monitor its behavior in the next days.
Best Answer03-24-2021 07:35
03-24-2021 07:35
Hi Lizzy!
To answer your question, no the Sense was never near anything that was cold. It'd display the message right after I take it off of my wrist or while sitting on my makeup vanity.
I actually utilized the chat feature to speak with a Customer Service Rep. We tried doing a factory reset and even that was unsuccessful. It wouldn't charge enough to do the factory reset so Customer Service shipped out a new charger to me since I only had the one that came with the device when I purchased it at the end of 2020. I'll post a follow up once I receive the new charger and re-attempt the factory reset.
03-28-2021
15:03
03:32
03-28-2021
15:03
03:32
Hi @brwneyedbrndi That's great news!
Thanks for the details provided, as well for taking the time to contact our Support team. I'm glad you'll receive a replacement charging cable to get your watch working correctly and I'm sure our team will do their best to bring you back on track soon. Please follow up with your email case should you have any further questions.
Best Answer06-09-2021 16:29
06-09-2021 16:29
I have the same problem. Were able to get it resolved?
18:33
08:20
06-14-2021
18:33
08:20
Hi @adoryab. Welcome to the Community.
Thanks for joining this thread. Because your post didn't mention, please try the steps described in this help article and take your Sense to another room making sure it's not too cold or hot. Monitor its behavior in the next days and let me know if the message disappears.
16:05
13:40
LizzyFitbit
06-17-2021
16:05
13:40
LizzyFitbit
Hi Lizzy,
Thanks for your post. I read the article you mentioned and none of them
relate to the issues. The Fitbit is simply dead. Please let me know if
there is anything else I can do. Otherwise, I will have to return the
device.
Thanks
Moderator Edit: Personal info removed
06-21-2021
13:43
03:34
06-21-2021
13:43
03:34
Hi @adoryab. It's good to see you again.
You're welcome and thanks to you for checking the help article shared in my post. I'm sorry you're having this experience and because the issue persists, let me recommend getting in touch with our Support team so they can evaluate your options and bring you back on track. Please click here to get connected with them, and make sure to share all the steps you've tried so far.
Best Answer05-04-2022 15:29
05-04-2022 15:29
Hi there did getting a new charger work? I am having the same issue with my verse 3, I have currently got it wrapped in a blanket in the hope that will warn it up!
05-06-2022 18:42
05-06-2022 18:42
21:27
07:49
DavideFitbit
06-09-2022
21:27
07:49
DavideFitbit
Hi, I'm having the same problem and have a FitBit Sense. I've had it since January 17, 2022. What should I do please?
I followed all the suggestions too and my Sense still isn't charging.
14:19
08:21
06-12-2022
14:19
08:21
Hi there, @MitsSF.
Thanks for letting me know about your Sense and trying the suggestions shared in this post. I went ahead to check your details and it seems you already have a case created with our Support team. They have specialized tools that will allow them to investigate and help you with this matter, so please keep an open communication with them.
06-12-2022 15:16
06-12-2022 15:16
I logged a chat with support and explained everything in detail, there were a couple of emails and in the end I returned my Sense and received a replacement about 10 days later. It’s not a repair as there were some scuff marks on my previous one which are not there now. Charged it when it arrived last Tuesday and is now at 34% six days later so battery is definitely working well. Good luck with support!
06-12-2022 16:35
06-12-2022 16:35
Thanks! Yes I have case open and need to return. I need to find a printer somewhere, lol! Best, MitsSF
06-13-2022
11:48
08:22
06-13-2022
11:48
08:22
Hi there, @Eoinfw and @MitsSF.
@Eoinfw Thanks for keeping me posted. I'm glad your replacement is working well and I hope you can keep crushing your goals.
@MitsSF I appreciate the time taken in contacting our Support team. Your case is in good hands and I'm sure our team will continue working on this until you're back on track, so please keep an open communication with them.
07-03-2022 13:58
07-03-2022 13:58
My wife is having the same problem. Here temperature is 30 °C but still getting the error continuously. It charge few seconds then buzz then error like this in a loop.
We have opened a case hope thy will fix
07-04-2022
16:35
08:22
07-04-2022
16:35
08:22
Welcome on board, @Joulebsv.
Thanks for letting me know about your wife's Sense, and your efforts while working on this. I'm glad you have a case created with our Support team and I'm sure they'll continue helping you, so please keep an open communication with them.
Best Answer07-04-2022 23:59
07-04-2022 23:59
After a while we have fixed it.
1. we first did a shut down of the watch, but nothing happen. after it started it was the same as before
2. then we have tried a factory reset. by resetting the watch we hoped it could be fixed. nothing
3. the solution for us was to long press the function button. press it and keep it pressing. after a while the watch turns off and on again. that somehow fixed the problem
meanwhile the service had given us a voucher to send them the watch via DHL, luckily we won't use it, at least this time.
bye
07-08-2022
14:35
08:22
07-08-2022
14:35
08:22
Hi there, @Joulebsv.
That's great news. Thanks for sharing the steps that worked for you, and I'm also glad you received help from the Support team. I'm sure your post will help other members experiencing similar issues. I hope your wife can keep crushing her goals and if you need anything else, don't hesitate to let me know. Happy stepping!
Best Answer08-14-2022 04:45
08-14-2022 04:45
Hi I have the same issue with my versa 3. I have gone through the trouble shooting, done a factory reset also held the function button for a restart. Still not charging. Any help would be greatly appreciated.
Thanks
